i need help pleaee
  • May 13, 2023 4:33 PM UTC
  • 288 views
Hey so my phone I have a iPhone 14 plus it cracked and screen wont work I can’t use my SIM card in my iPhone 12 so I can’t make a claim so what am I supposed to do
Best answer by MilkyWay
Did you sign up for Device Complete Care? If not, have you considered bringing the phone to your nearest Mobile Klinik location or local mobile phone repair store to get your screen fixed?
  • May 13, 2023 4:40 PM UTC
  • Organizer
  • May 13, 2023 4:56 PM UTC
Hey, we do have device care, the nearest Koodo is about 4 hours away
Allan M
  • May 13, 2023 5:11 PM UTC
With Device Care Complete you can make the claim here: https://www.phoneclaim.com/koodo/ or if you’re having troubles doing it online, call 1-844-574-1839.
  • May 13, 2023 8:41 PM UTC
Why happens when you try to use your sim in your iPhone 12? They both take the same sim card size so it should work.
  • Organizer
  • May 14, 2023 2:08 AM UTC
It did thank you I tried last night and I thought it didn’t fit because I was kinda worked up about my phone breaking
