every single incoming call (even those in my contacts) says Private Number
  • Jan 27, 2025 10:49 AM UTC
  • 3 replies
  • 433 views
As per title, every call is private and call display is not working. Very annoying.
I'm on a Pixel 7 and I tried adjusting in Settings and nothing seems to work.  It just started seemingly randomly, a few weeks ago.
​​​​​​Thanks in advance.
Best answer by Oliver C
Can you try calling *#30#? As it will tell you if incoming caller ID is enabled on your device. If it says it is disabled, try calling *30# to re-enable it.
  • Jan 27, 2025 12:55 PM UTC
  • Jan 27, 2025 1:44 PM UTC
Wow I think that may have fixed it! Thanks!
  • Jan 27, 2025 1:46 PM UTC
No problem 😎 If you get more problems in the future, feel free to post them on the community again. 🙂
