easy roam travel pass and data use
  • February 10, 2026
  • 1 reply
  • 61 views
With the easy Road travel passes it says it includes the data use based on your plan.  If my plan includes 90gig does that extend to my travel destination then.  As in no charges for data.
Best answer by Sophia
Correct! With Easy Roam, you can use your plan like you are at home. One exception though: perks are only valid for Canada, so for example if you have the international unlimited calling perk, it won’t be valid abroad.
1 reply
Sophia
  • February 10, 2026
