Data Usage
  • Oct 11, 2024 12:19 PM UTC
  • 4 replies
  • 370 views
How do I check my data usage for the past six months?
Best answer by Boa_Guy Koodo
Hi there @Aunt Sha
You can check your data usage in real time by logging in to your Self Serve account. Select Usage from the Self Serve dropdown menu.
Click View details to access your data history for your current cycle, your previous cycle, and from the previous 2 months.
Mayumi
  • Oct 11, 2024 12:48 PM UTC
Log into self serve  > self serve > bill > download PDF .
Boa_Guy Koodo
  • Koodo Alumni
  • Oct 11, 2024 12:59 PM UTC
Hi there @Aunt Sha
  • Oct 24, 2024 6:49 PM UTC
Logging in to my account and selecting “Usage” does not work for historic data. It will only show me current usage.
  • Oct 24, 2024 7:41 PM UTC
Alternatively, you can view your statements back 15 months or so to view data used.
