Connection to network
  • May 21, 2024 11:44 AM UTC
  • 2 replies
  • 1005 views
We currently have fibre optic connection through Bell. previously our internet connection was via cable (Roger’s owned). If we switched to Koodo internet which of the two sources would be used to make the connection? Not really interested in going back to the cable supply. Thanks
Best answer by Oliver C
In your case, the lines that Koodo use will be from the Rogers owned copper cables. Not bell fibre as of the moment.  I hope this quickly makes your decision 🙂👍
  • May 21, 2024 12:05 PM UTC
Thank you Oliver C
