Call forwarding to voip
  • Oct 20, 2023 2:48 PM UTC
  • 4 replies
  • 246 views
Can call forwarding be used to forward messages and calls to a voip number?
Best answer by Sophia
Yes, for sure. It would have to be a Canadian number though - and make sure you are aware of the cost. I would advise you get the call forwarding add-on, and make sure you familiarize yourself with the fair use policy: https://www.koodomobile.com/en/help/call-forwarding
Edit: whoops, I see you can forward to all North American numbers - though in that case I’m not sure of the cost involved.
Sophia
  • Oct 20, 2023 4:06 PM UTC
  • Oct 20, 2023 4:50 PM UTC
Thanks very much Sophia.
Thanks Sophia,
  • Oct 22, 2023 10:28 PM UTC
Best Answer:
