Azores - Roaming - January 2025
  • Jan 24, 2025 8:32 AM UTC
  • 1 reply
  • 195 views
I would like to know if the Azores (Portugal) are still included in the destinations covered in the European Roaming package? The question was asked one year ago and Darius Koodo said yes, it was included. But this could have changed since last year, therefore I am asking the question again. Thanks
Best answer by Oliver C
So yes as Azores is a region in Portugal it is still an eligible location for easy roam. Besides the usual $16 a day, you can also purchase an easy roam pass now. This way, you can pre purchase an amount of easy roam for a cheaper price.
Portugal would be included in the European pass which has a 14 day or 30 day option depending on how long you're going, I suggest you check it out. More information can be found in the link 🙂
https://www.koodomobile.com/en/help/europe-easy-roam-travel-passes
1 reply
  • Jan 24, 2025 11:06 AM UTC
