News
What is an eSIM and an eSIM voucher?
  • January 9, 2020
  • 16 replies
  • 9174 views
Chris Koodo
An eSIM is an embedded SIM. Like a physical SIM card, an eSIM from Koodo allows you to connect to the Koodo mobile network.
An eSIM voucher contains a digital SIM that lets you access a cellular plan without having to insert a physical SIM card. This eSIM voucher also allows you to use up to two phone numbers on select smartphones.
An eSIM voucher can't be inserted or removed.
For more information please visit: https://www.koodomobile.com/en/help/esim-and-esim-vouchers
  • Member
  • January 10, 2020
Are the vouchers available in store now?
  • January 10, 2020
They answered in the thread….
To move one of your phone numbers to an eSIM, purchase an eSIM voucher at your nearest Koodo store and complete a SIM-swap using Self Serve. Check out our Store Locator page.
Koodo eSIM vouchers are not available at retail partner locations (Best Buy, Wal-Mart, etc).
  • Member
  • January 10, 2020
For an iPhone, does the physical primary SIM card need to be a Koodo sim, or can it be from another provider?
Allan M
  • January 10, 2020
Does the physical primary SIM card need to be a Koodo sim, or can it be from another provider?
Primary sim can be from anyone!
Are esims transferable when you get a new phone or do you have to purchase a new voucher each time?
  • January 10, 2020
You need to buy another one….
“ once an eSIM profile is deleted from the phone, you can’t scan the same eSIM voucher into another phone. An eSIM voucher can be used and scanned only once. You’ll need to purchase an eSIM voucher at your nearest Koodo store and complete a SIM-swap using Self Serve. “
Sounds like a rip-off, and another money grab.
  • January 10, 2020
Wow so 20 bucks each time? Yup that's a rip off. Pretty bad when big blue is the only one not charging for it.
Sophia
  • January 10, 2020
Whoaahhh!! So much for swapping phones on a regular basis!
  • January 10, 2020
It was a well-known issue with eSIM for all carriers with eSIM. Different phone would require different eSIM “code/voucher”.
The issue is the money that carriers ask to generate each eSIM.
If you are a frequent SIM swapper and don’t have access to self-serve to activate your SIM, don’t use eSIM or get a true “dual physical” SIM phone.
  • January 10, 2020
It's just too bad that what is supposed to be easy and convenient swapping or even storage of carrier profiles is being derailed by such absurd greed.
  • Member
  • January 11, 2020
Much confusion on switching physical Koodo sim for eSIM.  Documentation on process for iOS is written for new activations. If your device is already activated/active and unlocked, simply purchase the voucher in-store and perform a sim-swap online. Presto - eSIM done. You can ignore all the “secondary line only” info which caused much confusion in-store. (No fault of the agents...poor technical writing and inadequate FAQs)
triggered123
  • Guardian
  • January 11, 2020
It takes years for Koodo’s not poorly paid developers to implement this, and then they can’t even write proper instructions. None of that “must be” primary or secondary line nonsense should be there for iPhone. You likely need an internet connection to add the eSIM, and they forgot what Wi-Fi is.
  • Advocate
  • October 11, 2022
I will be traveling to Europe and want to buy an airalo e-sim for my iPhone. Will it work? Or fo I need to buy something from Koodo to travel without easy roam for data? Thx!
Allan M
  • October 11, 2022
That is a question for airalo to make to sure your phone would be compatible with their services!
  • Member
  • June 12, 2024
It's very disheartening to think they invented something only to be able to use it in one phone
