will it affect my current plan if I deactivate and then reactivate my data plan?
  • Apr 10, 2023 6:47 PM UTC
  • 3 replies
  • 90 views
I am planning to go travel for two or three months, and I will not use koodo mobile plan for that period of time so I want to temporarily deactivate it. But I also want to keep the current plan and all the adds-on I have and continue use this plan after I done my travelling. I am worried if I deactivated my plan, I will not be able to keep my current data plan, which is really great for me. What should I do?
Allan M
  • Apr 10, 2023 6:54 PM UTC
You would be correct,
Seasonal hold is considered a plan change so if you do that, you’ll have to choose an in market plan when you get back.
  • Apr 10, 2023 7:06 PM UTC
There's no options really to keep your plan unless you pay as if you were using it 😢
  • Apr 10, 2023 10:36 PM UTC
If you care about the plan you have, you unfortunately are better off just paying as per normal. Especially for a shorter time period like that. If you were close to Black Friday/Boxing Day deals on return, it might be worth it then. Unless the timing works out, better to hold onto it.
