Why was I charged for long-distance calls?
  • Apr 27, 2023 9:51 PM UTC
  • 4 replies
  • 295 views
I am located in Toronto and my partner is located in Greenstone, ON for work.
Both of our phone plans are with Koodo and we both have Canada-wide minutes on our plans. However, my partner was charged for long-distance calls. What is going on?
Best answer by Bernard Koodo
@mobilepl4n The line that incurred the charges has a $15 a month plan that includes 100 Canada wide minutes per month. Going over that would come with additional charges.  You can see the detailed number of minutes used for the last month on the pdf version of your bill.
  • Apr 27, 2023 10:26 PM UTC
Are you certain you and your partner’s plans include Canada-wide minutes?
Can you post a screenshot of the long distance charges?
When posting a screenshot, please block out your personal information as this a public forum.
  • Apr 28, 2023 2:36 AM UTC
Hello there,
Is it you or your partner that got charged long distance? You were mentioning in the title that you got charged, but then in your message it is mentioning that your partner got charged.
  • Apr 28, 2023 2:56 AM UTC
Did your partner recently change their plan? That may explain why they may be charged.
Bernard Koodo
  • Apr 28, 2023 4:47 PM UTC
