why do i get charged with Unlimited Canada wide calling
  • Sep 2, 2022 3:00 AM UTC
  • 2 replies
  • 286 views
I just switched to a plan with Unlimited Canada wide minutes, but I just saw Usage page, and there are charges for calls. Why do I get charged?
Best answer by Boa_Guy Koodo
Hi there @r3356
We have looked into your account, and the charges are normal as you have used up all your minutes before the rate plan change.. You had a 300-Min plan. You also have other charges before that day if you check.. The good news is that you won’t see any of these charges again, since you now have a Canada-wide unlimited plan.
Hope this helps. :)
  • Sep 2, 2022 3:13 AM UTC
It is likely a glitch that occurred when you switched your plan. I have flagged a Koodo rep to help you out.
Boa_Guy Koodo
  • Koodo Alumni
  • Sep 2, 2022 11:50 AM UTC
Hi there @r3356
Hope this helps. :)
