Roaming Charges- close to US border
  • March 28, 2025
  • 1 reply
  • 15 views
Hi there, I was charged roaming charges when on Vancouver Island in BC.
I have turned off my roaming network on my phone and somehow got this again.
Please kindly remove from my statement. Thank you!
Did this help you find an answer to your question?
1 reply
Darius Koodo
  • 1158 replies
  • March 28, 2025
Hello ​@melitat
Sometimes the device is going to catch the network on the other side.
It's a world-wide situation, since the device settings are set to automatically search for the strongest signal.
You can change that in the settings of the device and set it to Manual Network Selection, after it's done searching, you select Koodo and it stays connected to Koodo, even near the border.
I would also advise to keep Data Roaming off while in Canada. This will avoid any accidental charges. We have a great help page here: https://community.koodomobile.com/plans-services-232910/easy-roam-understanding-how-you-will-be-charged-while-traveling-7811296
We verified the day with the charge and confirmed accidental roaming. A credit was applied for the fee and will update within 3-5 minutes in the Self Serve account.
