roaming charge by mistake in Nov
  • December 20, 2025
  • 2 replies
  • 37 views
While I was away overseas in Nov, I was using my esim but I noticed that I was being charged for$72 for roaming charges. Please remove $72 from my account, thank you.
Best answer by Flo Koodo
Hi ​@Eugeniachan
We have looked into it and we can see the charges were triggered due to a call and outgoing texts, we recommend checking the usage section in self serve for more details and let us know if you have further questions.
Any usage made in roaming, except for incoming texts, triggers the roaming charges
For more details, please check the link shared by DInh above.
  • December 20, 2025
Did you receive a notification from Koodo that your phone is roaming? If that is the cases, there are many possibilities. I would recommend you go into self-service and check usage of data/SMS/call to see if anything is reported there
This link might also help https://www.koodomobile.com/en/help/understanding-how-youll-be-charged-while-travelling?
  • December 21, 2025
Hi ​@Eugeniachan
