roaming charge
  • January 19, 2026
  • 92 views
We were charged roaming fees yesterday. We did not leave Canada but we do live close to the border in osoyoos. Please remove them asap.
Best answer by Oliver C
Was this just the roaming notification? As you will have to wait until your next billing cycle for the charge to show up before it can be credited. Many of these charges get screened out before you receive the bill, so it may not show up.
Going forward, I suggest you follow the steps in the article below to prevent roaming charges when close to the border in future. Specifically, about turning off roaming and adjusting your carrier selection settings. 🙂
Understanding how you'll be charged while travelling | Koodo Mobile
  • January 19, 2026
  • Advisor
  • January 20, 2026
When I go into self serve and click on minutes it is showing a charge for Er/vc for $16.00. We need to be in touch with our family and work so can not turn on airplane mode if we may be near the border. We were on mount baldy which is further away from the border than my office so this should not have occurred. Please ensure we will not be charged.
  • January 20, 2026
Koodo typically wouldn't do anything until the bill is generated in your account. I would recommend you come back here and once you had the bill with that accidental roaming fee. A rep should be able to assist and give you credit for that.
Koodo postpaid customer technically can't prevent the phone from US roaming. When the US tower signal is stronger, the phone automatically switch to it. To prevent that from happening, you can disable data roaming your phone. As well, disable automatic carrier selection in your device. Manually select Koodo will help.
  • January 26, 2026
I live in White Rock and a few weeks ago we were travelling on 0 Ave which is along the US border and my son was charged $16 roaming fee. What can I do to have this fixed?
  • January 26, 2026
Have you received the latest bill yet? As well, is your son number on the same account with yours?
  • January 26, 2026
@Nick Nickson It would be the same as what I said above. If the charge has yet to appear on the bill, wait for it to show up as it may just get screened out.
If the charge has shown up, please create your own thread and we can assist you there. 🙂
