roaming
  • February 3, 2026
  • 3 replies
  • 44 views
On Jan 23 & 24th my phone connected to a US network while I was traveling - but I never left Canada. Can you make the correction so I don’t get roaming charges? Thanks!
Best answer by Flo Koodo
@ttocs
We have checked and the bill is not yes posted, however once the bill is issused, please let us know and we will look into it.
Thank you!
  • February 3, 2026
Let me flag a rep for you.
To prevent this in the future, please make sure you change you network settings from Automatic to Manual and then select Koodo.
  • February 3, 2026
You will need to wait until the bill is issued before a rep can assist you.
To add on to Dennis, you will need to do this every time you restart your phone, since it will return to its default settings.
In the meantime, you may want to upvote this idea. If there are enough votes, Koodo may consider this option in the future.
  • February 3, 2026
@ttocs
Thank you!
