request to reverse roaming charges
Hi. On my most recent phone bill I have $42 dollars worth of incorrect roaming charges. I live close to the US border, still in Canada, and I constantly experience this. I’m making a request to have these reversed. Thank you!
Did this help you find an answer to your question?
  • 17374 replies
  • March 23, 2025
Let me flag a rep to look into it.
There seems to be multiple of instances of roaming days there. Did you disable data roaming in your device? as well try to disable automatic carrier selection in the phone, manually select Koodo would help you to avoid this.
  • 5969 replies
  • March 23, 2025
Hi ​@Hannahelizabeth
We have reviewed the details and we have been able to remove the roaming charges since they were triggered due to accidental roaming, feel free to check the details in your self serve account when you get the chance.
We recommend switching data roaming off and also switch to manual network and select Koodo, this would prevent the connection to a US tower when near the border.
For more info about how to prevent accidental roaming charges, please check out this article https://community.koodomobile.com/plans-services-232910/easy-roam-understanding-how-you-will-be-charged-while-traveling-7811296
Also, feel free to check the available  plans in your self serve account, as you should be able to see a Canada-US plan available for the line ending in *32, which comes with the same speed as your current plan, but with more data https://www.koodomobile.com/en/help/changing-your-rate-plan. The cost is the same if you set up a pre-authorized payment method.
With a Canada-US plan, there will be no fees for when the phone picks a US tower while near the border,. On top of that, you can use your phone without additional charges in US (some exceptions apply). More about Canada-US plans, you can find here https://www.koodomobile.com/en/help/traveling-with-your-canada-us-rate-plan
