PST charge
  • Apr 19, 2023 5:35 PM UTC
  • 266 views
Hello! Just wondering if getting charged PST in bills even after moving to Ontario is normal
Thanks!
  • Apr 19, 2023 5:59 PM UTC
Did you change your number to an Ontario one? I believe that Koodo defaults to charging you taxes and fees based on your area code. I have an out of province number from where I live and I am charged fees based on where my number is from.
  • Apr 19, 2023 6:01 PM UTC
No i havent. I just changed my address to Ontario l. I thought that should have done the trick. I get charged HST-ON, GST, PST
  • Apr 19, 2023 6:20 PM UTC
PST from which province? Are you getting double charged taxes? That shouldn’t happen. It doesn’t show up like that for me.
  • Apr 20, 2023 2:59 PM UTC
Login to your self serve and download your detailed pdf ebill.
What does it say around pages 2-4 about your tax?
Chris Koodo
  • Apr 20, 2023 6:02 PM UTC
@Huzhuz911 - Taxes for the plan are actually determined based on the phone number while taxes for usage is based on the phones location.
Based on your invoice, it looks like you were charged a little bit of HST-ON for a short long distance call that was made while you were in Ontario.
In order to change the taxes completely, you would need to change your phone number. Hope that helps!
