Answer
please remove roaming charges
  • November 20, 2025
  • 3 replies
  • 34 views
hi there,
i have more roaming charges on my account. please remove them. we live close to the USA. anytime my phone is turned off or reset i have to manually select koodo BUT i dont have service at my home so AS SOON as i enter a service zone my phone AUTOMATICALLY connects to a USA tower and starts roaming. it is IMPOSSIBLE for me to  avoid these charges despite following all directions from Koodo.  and yes, my phone is set OFF for roaming.
Please see that I have not travelled into the USA and reimburse all roaming charges.
thank you kindly
Best answer by Allan M
I’ll flag a rep since you haven’t left Canada.
Id check your self serve account and see if one of the Canada-US roaming plans would suit you as well. It may be more than what you’re currently paying but may also be the same/cheaper or just worth not having to deal with the extra charges each month.
Allan M
  • November 20, 2025
  • November 20, 2025
Have you tried using wifi calling at home?
  • November 20, 2025
Hi ​@dfefdfdfd, we’ve checked the charges you mentioned and as they are accidental roaming we have added a credit, it will be reflected on your account in 24-48 hours.
To avoid future charges please make sure that the data roaming is off in your phone settings and you are manually connecting to the Koodo network.
For more details on how to prevent accidental roaming charges, you can check out this article.
If you’re living/travelling very close to the border, you may also be interested in our Canada-US plans, more information here.
