Occasional Send/Receive Texts Overseas
  • Dec 7, 2023 11:36 PM UTC
  • 1 reply
  • 81 views
I’ll be in the Middle East for a month or so and want to be able to use my Koodo monthly prepaid plan to send and receive texts. I won’t be using voice at all. EasyRoam is ridiculously expensive for me needs. My questions are:
  •  During my stay in the Middle East, what is the cost of receivng a text from Canada? If it’s different, what is the cost of receiving a text from another country?
  • What is the cost of sending a text to Canada? If it’s different, what is the cost of sending a text to another country
I’m honestly a bit underwhelmed by the lack of clear cost info from Koodo. It seems like all it wants to do is pitch EasyRoam.
Thanks for your help!
1 reply
  • Dec 8, 2023 1:06 AM UTC
Simply put, prepaid accounts cannot roam outside of the US. You will not be able to use it at all.
Sure, it’s an easy 16 dollars a day and they keep upping the limit of total cost. It’s quite the cash cow.
If you opt for a postpaid plan, then yes, it’s free to receive texts anywhere in the world. The cost to send is usually 60 cents per 1 outgoing SMS (160 characters).
My suggestion, since you likely want to stay on prepaid (unless you want postpaid), is to get a Canadian voip line or use a roaming esim company. Then you can send/receive texts for pretty cheap.
