Moving from Ontario to Alberta - Tax Question
  • Apr 9, 2022 5:24 PM UTC
  • 2 replies
  • 216 views
As I said in the subject, I moved from Ontario to Alberta and would like to change the way I get taxed.. Not sure how to do it in the self serve - billing address has been updated to Alberta address in the Self-serve. Thanks
Best answer by Dinh
I believe the tax was charged based on the area code you had on your number. Unless you changed that number to an Alberta one, you would still be charged by Ontario tax rate.
  • Apr 9, 2022 5:52 PM UTC
  • Apr 9, 2022 6:42 PM UTC
Thank you..
