Koodo and my Phone Disagree on my Data Limit
  • Aug 24, 2023 12:27 AM UTC
  • 112 views
William Frank Wall
My phone says that I’ve used only 296MB of my 2GB limit.  But I was getting text messages from Koodo saying that I’ve used up my 500MB limit.  Why do they disagree?  Makes no sense.
  • Aug 24, 2023 12:39 AM UTC
Does your phone’s monthly data tracking cycle match up with your  billing cycle?
William Frank Wall
Apparently not.  But that does not explain the discrepancy in my data limits given by Koodo and given by my phone.   My phone says it’s 2GB and that’s after talking with Telus support.   And Telus owns Koodo.
  • Aug 26, 2023 5:03 PM UTC
Were the billing cycle was set to the same billing cycle date from Koodo?
If possible, could you tell us the billing cycle date in your Koodo bill and a snapshot of your cellular data usage (hide/delete all personal information before posting please)
  • Aug 26, 2023 5:16 PM UTC
I am not clear if you have set up your phone to match Koodo.
Your phone does not know how much data you have with Koodo nor does it know when your data/billing cycle starts and stops each month. It is  not automatic - you have to enter this info manually.
Allan M
  • Aug 26, 2023 5:32 PM UTC
It’s all set up by the user on their phone in settings, connections, data usage, billing cycle and data warning. (or similar depending on your phone).
You want to make sure you set your start date to the right date corresponding to your billing cycle, and if you have the data limit set, set that to how much data you have with Koodo.
