Incorrect usage charge
I’ve been trying to cut out extra costs on usage from texting US numbers by accident, so I’ve been checking my bill pretty regularly and cross checking the numbers. In this recent bill I noticed these two transactions:
for $2.55 (17 msgs) and $7.35 (49 msgs)
I looked under my usage and non of my messages correspond to these charges:
Should I be looking somewhere else for these charges? Or is this incorrectly charged?
Best answer by Boa_Guy Koodo
Hi there ​@NVic
We’ve reviewed your account, and the charges are accurate. You should be looking at the dates between 02/14/2025 and 03/13/2025, as usage is always based on your last billing cycle.
If you’re not currently using your Long Distance Perk, we recommend switching to the International SMS Perk instead. This way, you can text as much as you’d like without incurring any additional charges.
Hope this helped. :)
Did this help you find an answer to your question?
  • 17404 replies
  • April 2, 2025
Which plan are you on as of now, does the plan include international SMS/MMS or did you have a perk for that?
Boa_Guy Koodo
  • Employee
  • 1302 replies
  • April 2, 2025
Hi there ​@NVic
