incorrect Roaming Charges
  • January 12, 2026
  • 2 replies
  • 29 views
I have days of roaming charged on my latest bill.  I have not left Canada and these charges need to be reversed.
Best answer by Oliver C
I’ll flag a rep to check out the charges. Just make sure you’re logged into the community using your self serve credentials and they can take a peek.
Going forward, I suggest you turn off roaming and change your carrier selection settings from automatic to manual and then Koodo. This should help prevent this from happening again. Note some charges may have to be reset if you restart your device. More info can be found below. 🙂
Understanding how you'll be charged while travelling | Koodo Mobile
  • January 12, 2026
  • January 12, 2026
Hi ​@Mrgerbik
We have looked into it and we have been able to remove the roaming charges since it was due to accidental roaming. Feel free to check the amount due in self serve when you get the chance.
For more info about how to prevent  roaming charges in the future, please check the article share by ​@Oliver C above.
