incorrect roaming charges
Roaming charge when I did not leave the country
Did this help you find an answer to your question?
  • 13568 replies
  • March 31, 2025
I’ll flag a rep to assist.
For future reference, the following article explains how to change your phone settings that should prevent it from happening again. Note that restarting your phone has the potential to shift back to automatic selection mode:
  • 5960 replies
  • March 31, 2025
Hi ​@Canadianislander
We have reviewed the details and we have been able to remove the roaming charges since they were triggered due to accidental data roaming, feel free to check the details in your self serve account when you get the chance.
We recommend switching data roaming off and also switch to manual network and select Koodo, this would prevent the connection to a US tower when near the border.
For more info about how to prevent accidental roaming charges, please check out this article https://community.koodomobile.com/plans-services-232910/easy-roam-understanding-how-you-will-be-charged-while-traveling-7811296
Also, feel free to check the available  plans in your self serve account, as you might be eligible for a Canada-US plan: https://www.koodomobile.com/en/help/changing-your-rate-plan
With a Canada-US plan, there will be no fees for when the phone picks a US tower while near the border,. On top of that, you can use your phone without additional charges in US (some exceptions apply). More about Canada-US plans, you can find here https://www.koodomobile.com/en/help/traveling-with-your-canada-us-rate-plan
