Incorrect Easy Roam Charge
  • March 4, 2026
  • 4 replies
  • 31 views
Please Remove the most recent Easy Roam charge on my account. It is incorrect.
Best answer by Darius Koodo
Hello ​@customerlv
We have reviewed the details and we have been able to remove the roaming charge since it was triggered due to accidental data roaming, feel free to check the details in your self serve account when you get the chance.
We recommend switching data roaming off and also switch to manual network and select Koodo, this would prevent the connection to a US tower when near the border.
For more info about how to prevent accidental roaming charges, please check out this article https://community.koodomobile.com/plans-services-232910/easy-roam-understanding-how-you-will-be-charged-while-traveling-7811296
Also, feel free to check the available  plans in your self serve account, as you might be eligible for a Canada-US plan: https://www.koodomobile.com/en/help/changing-your-rate-plan
With a Canada-US plan, there will be no fees for when the phone picks a US tower while near the border,. On top of that, you can use your phone without additional charges in US (some exceptions apply). More about Canada-US plans, you can find here https://www.koodomobile.com/en/help/traveling-with-your-canada-us-rate-plan
  • March 4, 2026
Can you confirm if you mean you never left Canada and got charged roaming, or you were out of country, but got charged without actively using your phone?
  • March 4, 2026
I did not leave Canada in February. It is possible the charge came from a flight between Toronto and Vancouver. In either case I did not access my phone.
  • March 4, 2026
Let me flag a rep for you.
To avoid this from happening again, make sure to manually set your network to Koodo, so that your phone does not automatically connect to a nearby U.S. cellular tower. You will need to do this every time you restart your phone.
Darius Koodo
  • March 4, 2026
Hello ​@customerlv
