Incidental Roaming Charges
Hello,
My husband and I was travelling outside of the country and he accidentally hit the airplane mode button on March 28th but immediately hit it on again. I noticed that we got charged for roaming charges even though it only counted as one minute and we didn’t use the phone for anything. I am wondering if we could get the charges removed or credited for that date.
Thank you.
Best answer by Allan M
I’ll flag a rep to take a look since by the sounds of it, not much was used.
Did this help you find an answer to your question?
Allan M
  • 12328 replies
  • April 7, 2025
  • 6043 replies
  • April 7, 2025
Hi ​@TinyFingersForever
We have reviewed  the details and we have been able to remove the charge since it was due to data leakage.
For more info about how to prevent roaming charges, please check out this article https://community.koodomobile.com/plans-services-232910/easy-roam-understanding-how-you-will-be-charged-while-traveling-7811296
If you need to use your Koodo plan when roaming, we recommend checking the Travel Pass options here https://www.koodomobile.com/en/help/europe-easy-roam-travel-passes
