I was charged roaming charges despite not even touching my cell phone
  • Jun 20, 2023 5:44 PM UTC
  • 2 replies
  • 259 views
I live near the border and often travel across the border to get gas.  I was charged roaming charges the last two times I did this, despite not even touching my cell phone, let alone using it.  Please remove these charges.
Thank you.
Best answer by srlawren
 @JHawk just because you weren’t touching the phone doesn’t mean there wasn’t stuff going on in the background.  You may want to check out Koodo’s article on how to avoid this:
Mayumi
  • Jun 20, 2023 6:30 PM UTC
Can you check your phone settings?
If you are living close to border, you need to set roaming off, and  adjust your connection setting from auto to manually select to Koodo to prevent further charges.
srlawren
  • Hero
