I received a "welcome to the USA" msg. Will be charged for Roaming?
  • May 22, 2023 2:31 AM UTC
  • 2 replies
  • 186 views
I am currently in BC going to Vancouver Island, since I am near the USA I got a message saying welcome to the USA and that my phone is roaming. I really hope that I don’t get charged for roaming because I am NOT in the USA. Please help, thank you (:
  • May 22, 2023 3:31 AM UTC
From your description, it was just an sms about the accidental roaming. I recommend you wait until there was a report of actual roaming fee showing up in either usage or your bill. A rep should be able to revert the fee for you.
Generally, accidental roaming happened when us cell tower signal stronger than Koodo signal. To avoid it, you can try to disable automatic carrier selection and manually select Koodo. it might help in certain cases.
Thank you (:
