help !
  • Mar 30, 2023 9:52 PM UTC
  • 1 reply
  • 62 views
Jayson Luschtinetz
just purchased a phone plan with koodo online and they say it would say 1-2 business days to get my sim card, am i able to go into a koodo store to get it earlier? i would like so if possible as i need my phone for work thanks. heres the order number if that helps HFO35314351.
1 reply
Mayumi
  • Mar 30, 2023 10:17 PM UTC
Please keep your question in one place. You don't need to o create multiple posts to ask questions.
https://community.koodomobile.com/plans-add-ons-66722/help-7818450
And if you go into a store to receive a SIM, then they will charge you for the connection fee as Bernard mentioned on the other post.
