Fraudulent Long Distance Charges
  • Dec 1, 2022 5:03 AM UTC
  • 7 replies
  • 345 views
I logged on to my account and there are over $400 dollars of long distance calls to various African countries that i never made!!! What kind of system is Koodo running - the scheduled callback better have a solution immediately.
Allan M
  • Dec 1, 2022 5:07 AM UTC
That is strange indeed. And none of those calls can be found in your phones call logs?
As well, what kind of phone are you using/were you using when those calls were placed?
  • Dec 1, 2022 5:12 AM UTC
None of the calls are on the phones call logs. Its my fathers coolpad 3311A
Allan M
  • Dec 1, 2022 5:28 AM UTC
I’ll flag a rep to assist
  • Dec 1, 2022 5:32 AM UTC
Thank you! There are four more calls to Tunisia and Madagascar on the current billing period as well! This is insane and horribly disappointing.
  • Dec 1, 2022 1:20 PM UTC
Hi @Adri_2
We have sent you a PM, so we can further assist, plesae check the inbox under your community profile when you get the chance. Thanks!
  • Member
  • Jan 28, 2023 3:15 AM UTC
I just got my bill and there are $200 worth of long distance charges on my account that arent in my call log!! This has to be resolved asap!
  • Jan 28, 2023 4:29 AM UTC
I suggest you create a different thread of your own. A snapshot of the bill (without any personal information) is also helpful. A description of your current plan as well as detail issue description might be also informative for other to help you.
