Can you please remove the roaming charges from my bill. I live on a border town and often pick up US towers.
I will flag a rep.
To prevent future roaming charges, you can turn off the roaming on your phone settings, and set your connection manually select to Koodo.
This link will help:
https://community.koodomobile.com/plans-services-232910/easy-roam-understanding-how-you-will-be-charged-while-traveling-7811296
Hi ​@Kayla Anderson
We have reviewed the details and we have been able to remove the roaming charge for the one day for the line ending in *844 in since it was triggered due to accidental data roaming, feel free to check the details in your self serve account when you get the chance.
For the rest of the roaming charges, data usage indicates the phone was not connected to Canadian towers for more than 6-7 hours. If you wish to dispute those further, you can send us a message on social media using the links at the bottom of this page or you can schedule a call back with the virtual assist.
We recommend switching data roaming off and also switch to manual network and select Koodo, this would prevent the connection to a US tower when near the border.
For more info about how to prevent accidental roaming charges, please check out this article https://community.koodomobile.com/plans-services-232910/easy-roam-understanding-how-you-will-be-charged-while-traveling-7811296
Also, feel free to check the available  plans in your self serve account, as you might be eligible for a Canada-US plan: https://www.koodomobile.com/en/help/changing-your-rate-plan
With a Canada-US plan, there will be no fees for when the phone picks a US tower while near the border,. On top of that, you can use your phone without additional charges in US (some exceptions apply). More about Canada-US plans, you can find here https://www.koodomobile.com/en/help/traveling-with-your-canada-us-rate-plan
