easy roam charges
  • March 24, 2025
  • 1 reply
  • 18 views
I keep getting roaming charges on my bill because I live next to the border which is super annoying because I've turned my data roaming off! Please fix this 🙏
Did this help you find an answer to your question?
1 reply
  • 29056 replies
  • March 25, 2025
To prevent accidental roaming in the future you can change your network settings from Automatic to manual and select Koodo manually.
Also you can change your plan to a Canada-US plan and you will be able to connect to the neighbouring US networks without any roaming concerns
