Disputing Roaming Charges
  • March 7, 2026
  • 47 views
Hello:
I have a roaming charge on my bill.  May I please have this reversed.
Best answer by Dinh
I was using my travel esim and travel data plan
When you traveled outside of Canada, did you receive SMS from Koodo that roaming is active on your device?
I understand that you’re using a different SIM, but sometimes the phone—or the user—may inadvertently use the Koodo SIM for certain tasks. I recommend checking your Koodo data and SMS usage to see why Koodo believes they can charge you.
  • March 7, 2026
Let me flag a rep for you.
To avoid this from happening again, make sure to manually select your network to Koodo, so that your phone does not automatically connect to a nearby U.S. cellular tower. You will need to do this every time you restart your phone.
  • March 7, 2026
  • March 7, 2026
  • March 7, 2026
Hi ​@ShannaSB
We can definitely look into it from our end!
Can you please confirm the last two digits of the phone number in question?
  • March 7, 2026
There are two accounts that have the roaming charges
xx90 and xx78
Both numbers had travel esims and travel data plans
  • March 7, 2026
Thank you for confirming!
We have looked into it and for line ending in *78, we see the charge was triggered by a call (the details can be checked on page 7 of the PDF bill),  and for the other line, there were 2 outgoing text message, we recommend checking the usage section in self serve.
For more info about how to prevent unwanted roaming charge, we recommend checking this link https://community.koodomobile.com/plans-services-232910/easy-roam-understanding-how-you-will-be-charged-while-traveling-7811296
