Data Charges overnight?
  • Mar 11, 2023 2:46 AM UTC
  • 1 reply
  • 96 views
Hi - I checked my data use (very low) and see that there are several “events” that use data when I am asleep. Usually between 2:00 and 6:00 a.m. Most are for less than a MB but this week there was one that used 35 MB! Why?
I am not checking sites, receiving or sending anything. As I said, I am asleep and I don’t use my phone while asleep.
When my phone is at home, it uses my wifi so data should not be touched.
1 reply
  • Mar 11, 2023 4:19 AM UTC
Do you have the Background App Refresh feature on your phone? You can try turning it off to see if that would stop the data usage.
