Charged for Roaming and did not leave Canada
  • November 19, 2025
  • 40 views
My account was charged for roaming when I did not leave Canada. I would like a refund
  • November 19, 2025
When you login to your self serve and download your detailed pdf ebill, do you see the Easy Roaming charge on on page 3 under the Mobile Services section?
yes
  • November 19, 2025
Let me flag a rep to help you out.
To avoid this from happening again, you can manually select your network to Koodo, so that your phone does not automatically connect to a cellular tower. You will need to do this every time you restart your phone.
In the meantime, you may want to upvote this idea. If there are enough votes, Koodo may consider this option in the future.
Thank you!
  • November 19, 2025
Let me flag a rep for you.
To prevent this in the future, please change your network settings from Automatic to Manual and then select Koodo.  Note that you may need to reapply this setting change after a phone restart.
  • November 19, 2025
Hi ​@Scorrlikesapples
We have reviewed the details and we have been able to remove the roaming charge since it was triggered due to accidental data roaming, feel free to check the details in your self serve account when you get the chance.
For more info about how to prevent accidental roaming charges, please check out this article https://community.koodomobile.com/plans-services-232910/easy-roam-understanding-how-you-will-be-charged-while-traveling-7811296
