charged for long distance
  • Mar 22, 2023 9:35 PM UTC
  • 3 replies
  • 198 views
I was charged 36$ this month for long distance and I didn't leave Canada? Im near the USA borders.
Best answer by Boa_Guy Koodo
Hi there @Thalie
We have been able to review the account and we were able to see that you never left the country, therefore we have been able to adjust your bill.
As @rikkster mentioned, turning off data roaming and switching the network to manual (and selecting Koodo) should prevent the accidental usage while near the border, here you can find out more
Boa_Guy Koodo
  • Mar 22, 2023 10:34 PM UTC
If you live or travel close to the U.S. border, it's best to turn off automatic network selection and manually select Koodo as your mobile network operator. To avoid roaming charges, turn data roaming off. If you need assistance with these settings, let us know which phone you have.
I have flagged a rep to help you with this.
Mayumi
  • Mar 22, 2023 11:11 PM UTC
Can you login to your self serve and check which number/area code  you got charged?
You mentioned that long distance charge- you might call to US?
Boa_Guy Koodo
  • Koodo Alumni
  • Mar 23, 2023 11:33 AM UTC
Hi there @Thalie
Boa_Guy Koodo
