Charged for Long Distance
  • Dec 26, 2022 4:20 AM UTC
  • 7 replies
  • 271 views
I recently switched my plan during Black Friday and recently got the bill. Both plans had Canada-Wide Long distance included. However I got charged for calls made to Ontario numbers, while in Ontario. I never had this issue before. Can anyone help me look into this? Thanks
Best answer by Dinh
This seems to be a glitch when you changed your plan. Let me flag a rep to look into it
  • Dec 26, 2022 4:43 AM UTC
  • Dec 26, 2022 6:53 PM UTC
Hello @scrapiron! We have applied the necessary adjustments and you can check your new amount due in Self Serve.
  • Dec 27, 2022 11:36 PM UTC
thanks for fixing it so quickly! @Lavinia Koodo @Dinh
  • Jan 13, 2023 10:52 PM UTC
Hey Koodo,
The same ‘glitch’ above is impacting me. My bill has been more or less stable for 18 months. This month I’m getting over $10 in long-distance, for 2 calls within Canada, shortly after changing my plan.
I can’t find a number online to call you, and the earliest callback from the self-serve platform says I have to wait 2 full days from now.  Please help.
  • Jan 13, 2023 10:53 PM UTC
Hey Koodo,
Let me flag a rep for you
  • Jan 13, 2023 11:03 PM UTC
Hello @Perplexed! We have applied a full credit for the long distance charges that were triggered in error, you can check your updated amount due in Self Serve.
  • Jan 13, 2023 11:05 PM UTC
Ok, thank you.  I am actually slightly stunned at how quick & easy you made that happen.  I appreciate your help.
