billed $11 for US roaming AND $23.30 for a phone call while using EasyRoam
  • Sep 10, 2022 11:17 PM UTC
  • 7 replies
  • 282 views
I have Easy Roam set up and was automatically charged the $11/day when I used my phone for the first time when I went down the the US. I just checked my bill and I was also charged a per minute rate for several calls I made down there, while I was supposed to be on Easy Roam! How do I get this fixed, as I can’t talk to a human about it.
  • Sep 10, 2022 11:34 PM UTC
So you were charged both easyroam and outgoing at payperuse rate? Were those call to a US or Canada number? Were those toll-free number?
  • Organizer
  • Sep 11, 2022 5:20 AM UTC
Correct: I was charged $11 earlier in the day, and then used my phone to call a US number in the US, and was charged pay-per-use. How do I talk to a human to resolve this?
  • Organizer
Two days in a row this happened.
  • Sep 11, 2022 12:50 PM UTC
You’ll need to schedule a callback using the Koodo's Digital Asistant : koodo.com/chat
  • Sep 11, 2022 3:25 PM UTC
Hello @oggiedoggie! We checked the charges and it looks like your phone accidentally connected to a Canadian tower while you were in the U.S. on August 11th. We adjusted the long distance charges and you can check your updated amount due in Self Serve.
  • Organizer
  • Sep 11, 2022 11:53 PM UTC
https://community.koodomobile.com/members/lavinia-koodo-9802129
Hi Lavinia Koodo,
thank you so much for your help!
I can’t easily see on Self Serve the charges that youactually removed. Specifically, I see the “Amount Due” went from $136.19 to $103.04. But where does it show what you credited back to me?
There is another issue on my bill: I was charged $11/day on both August 14 and 15, but in the time zone that I was in, the charge on 15th was actually still on 14th, my time! So the charge is in error. Can you fix this as well. Also, EasyRoam is supposed to be for 24 hours. Instead of four easyroam charges, I should only have 3.
The physical location where I was in the US is somewhere I will return to, and so this may happen again. How do I ensure this does not happen again? Otherwise I need to go find a different carrier.
Thanks again!
Laura
  • Sep 12, 2022 1:35 PM UTC
Hello @oggiedoggie! We’ve just left a message in private with more details about the adjustments.
