My plan offers a $10 credit for auto-pay. Under billing in self serve I see the Bank and Credit Card options. So if I use my credit card will I get the $10 bill credit.
Auto-Pay $10 Credit - Using Credit Card
Best answer by Oliver C
Ah yes, so the option to use that as a payment method is still available to you, however, that may not necessarily mean you will still receive the auto pay discount.
The auto pay discount will depend on the plan be it if it is one that is applicable for either auto pay by bank account or by pre authourised debit / credit, though the second has been phased out a bit
If you follow this link and get to the "change my plan" step, when you see your plan when you go to change it what does it say? It should tell you there what it is applicable for. An example is my plan in the image below.
Login to the community
or
