Received a call on January 2,  2025 from 1 (778) 534-4349 claiming to be from Telus (something) saying I won a phone.
They then proceeded to ask identifying questions – email, address, birthday – though, in regard to the latter two, not necessarily all of the information (unit # & birth year). Then they asked for a PIN number which, in my opinion, was the deal breaker and after I balked and suggested that Telus/Koodo say they would never ask for that they eventually hung up.
Reverse lookup suggests the number is part of the Shaw network.
Anyone else get a call from that number that can verify it being a scam?
This would be a scam. Phone companies will not give away phones for free and you're correct, unless you agree to a phone sale with koodo/telus they will not ask you the verification questions. Especially when you started to ask questions and they hung up, this is a bit of a give away.
If you receive a call from koodo or Telus, it will commonly be a 1-866, 1-844, 1-833 or 1-877 number. Chris from koodo had actually made a great article outlining this and more in the link below. I suggest you give it a read. I hope this helps 🙂 sorry this happened to you.
https://community.koodomobile.com/privacy-security-and-fraud-232911/was-that-a-scam-or-did-koodo-just-call-me-7809115
Thanks Oliver, that’s a great resource!
Hopefully an email address (not important one), my birth year and condo unit aren’t enough to do whatever they plan/planned to do.
Too bad about the phone, though.
