Yesterday I reset my networks and that erased all my Bluetooth connections. After I redid those, I can't seem to send or receive pictures messages now?
Best answer by Dinh
View originalYesterday I reset my networks and that erased all my Bluetooth connections. After I redid those, I can't seem to send or receive pictures messages now?
Best answer by Dinh
View originalWhich phone are you using? if it is an Android, can you check your APN settings and see if it was reset correctly as per this https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone
Also, I assumed your cellular data was ON?
Thanks. Yes it's an Android data is on and yes I checked those settings
Can you post a snapshot of your APN settings in the phone here? If it worked before and now it didn’t work, the MMSC might have set incorrectly.
Your MMS proxy and MMS port wasn’t set correctly as per Koodo page above. Those value should be:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
I recommend you fix it and see if MMS works again.
MMS Port: 8799
Omg thank you SO much! Success! Appreciate the help!!
MMS Port: 8799
MMS Port: 8799
Very helpful! Thanks so much!!!
