i can not enable my wifi calling, when i try its saying (to allow wifi calling on this acount, contact Koodo)
Hi
However the issue for your account is also that you no longer have an active SIM, the eSIM you activated recently was deleted from your phone. You will need cellular service for the initial Wi-Fi calling activation.
Once deleted eSIMs cannot be re-scanned so you will need another voucher. If you were using a physical SIM card prior to this, you can reactivate it instead via your online account, here is a guide https://www.koodomobile.com/en/help/koodo-sim-support If the verification code cannot be sent via email you will need to schedule a callback through the Koodo Assist
Login to the community
