I have never had a password on my voicemail. Went to check my voicemail today and it says I require a password. If I ever had one I don’t know what it was so I selected the option to reset the password. I get a text with temporary password in order to reset the password, but then I’m told the password is invalid. I’ve attempted to reset 3 times and each time it sends me the same “temporary password” and then when I enter the password it tells me it’s “not the correct password.” So I have voicemails but cannot check/access them. How can I can I fix this?
It sounds like you are doing everything right.
Let me flag a rep for you
Hi ​@Slittle8, we’ve reset the password on our end. The temporary password should be your 10 digit phone number.
Thanks. It’s all good now
