I insert koodo sim card in other mobile. It's shows no service while.I add same card in other mobile than it's work. Even I add other sim in mobile than it's work.
Hi
Is it also a Koodo sim the other one that you insert in your phone and it works?
When did you notice that your Koodo sim doesn’t work with the current phone?
Which phone are you currently using? Is it compatible with the bands and frequencies for the Koodo network? https://www.telus.com/en/support/article/how-to-use-volte
Login to the community
or
