I would like to get an old number that I had changed thinking I no longer needed it. The problem is I didn’t change my banking info and other login info before i did the number swap and now need the old number for that purpose. Is it possible to get that number back?
When you did you change your number to the new one? If you wanted to switch back (I assumed nobody took the number), you would have to contact Koodo directly by scheduling a call back and ask a rep to look into it.
