Just got the Ulefone Ultra 26 and everything seems to work fine but I can't send any MMS messages.
Have no issues with text or calling.
Do you have data on when you trying sending MMS?
Also make sure your apn settings is correct.
https://www.koodomobile.com/help/setting-data-your-non-koodo-phone
Tried and it didn't work, everything looks the same other than two things that I edited
Did mms work previously on your old phone?
If editing the apn doesn't work, trying creating a new apn
Im pretty sure it did, had group chats with pictures/gifs .tried making a new one/updating the old one and it didn't seem to fix it. Still getting the trouble sending error
I just set it back to default,this is what it currently looks like
Check out this post in detail including links to other posts within it. A lot of folks were able to get their MMS fixed with some minor tweaks to the APN
Just tried to check it out but it says it's an old post
Let me flag a rep to unarchive the post
I don’t think the information in the archived link would work. Some found it worked for 1,2 days then it stopped.
If your phone wasn’t on the Koodo’s MMS supported list, it wouldn’t work as they stated it here https://www.koodomobile.com/en/help/picturemessagingchanges
