I am using Koodo since August 2024. Coming from Telus. I had Iphone 14 pro and the internet speed was really good and there were no problem.
Recently I got a phone plan from Koodo and purchased Iphone 16 pro and my internet speed always slow even the cellular shows 4-5 bar. The contents are looading slowly.
Plus, I live in heart of downtown Vancouver,BC. Is there any recent issue with new iphones anthenna? Or is it something related with Koodo? If there is no issue with iphones, i will likely cancel and return the phone and join Telus or Rogers
Hi
Will you please let us know what speeds you get if you run a speed test here https://www.speedtest.net/?
Have you tried resetting the network settings on your phone? (this will reset the saved bluetooth and wifi connections)
Hi Yes, I tried resetting network as well.
The internet speed is always around 90-100 Mbps which should be okey to load the content. Not sure why there are some slowness.
Koodo is using Tellus/Bell network. It shouldn't be an issue in the area where Telus signal was good. Were you testing speed indoor or outdoor? Did the issue happen everywhere you do?
Yes, I have been testing the internet about 1 week. It happens everywhere indoor and outdoor. And I am working and living in downtown vancouver.
Are you using any type of VPN profile on your device. I am in the greater Vancouver area as well. I personally didn’t have issue with downtown area.
In the worst case, I recommend you visit a local kiosk there and ask a rep to check.
Hi, no i don’t use any VPN.
Are you using the normal Ookla speedtest? what was the “ping” time? I wonder if the phone didn’t share the location and your test server was off.
As I mentioned earlier, you could try to visit a Koodo location and ask someone there to check.
Login to the community
