Hi, I'm receiving messages but I can't call, already tested all network solutions but nothing ( reboot, network settings...). Somebody could help me?
Have you tried putting your SIM card into another device to see if it works?
Yes still doesn't work
Did you recently port over to Koodo? It is possible the transfer was not completely successful. You may want to contact the Koodo porting department at 1-844-232-7678.
I trying but the call does not go through,
You can download an app that can make and receive calls, such as Fongo. If the porting department is not able to assist, you can schedule a callback through Koodo Assist to that number instead.
Thank you I'll try
I'm in Canada, and it's not available at the store...
That is strange. Are you able to use data on your phone?
Yes
Can you download this app? You can make and receive calls with TextNow.
No. I'm not lucky wtf
No again
I think it's because I don't have 3G network, when I switch to 4G everything is fine except the calls, but when I switch to 3G I don't have network anymore.
Hi
When did the issue start?
Can you please turn your phone off for 10 minutes and let us know here once it’s turned off or right before you turn it off?
Started this morning (ET), okay I'm gonna turn off my phone for 10 min
Thank you!
If possible, please test if the calls go through once you turn your phone back on.
Same result I can't call. But network and text are okay
Are you a new customer?
What phone are you using and where did you get it from?
What error are you getting when you try to make a call?
WHat if someone calls you,? Are you able to answer?
No I'm not a new customer, I use koodo on this phone since a year.
What phone are you using?
What if someone calls you,? Are you able to answer?
Using Xiaomi
I don't get any error the call doesn't go
I can't receive any call either
Since it is also not working on another device, it may be an issue with your SIM card. You may want to go to your nearest Koodo store to get a replacement.
I have the same issue. Phone has been working flawlessly for over 4 months and now all of a sudden it cannot make it receive calls. Data and text are working fine.
(Nothing phone (2a))
Which xiaomi phone? You said you put the sim card in another phone, and it still didn’t work with that other phone?
I have power cycled. Re-checked my APN settings. Tried 5G and 4G as well as 3G. 3G I get no signal no signal issues with 4G or 5G. But nothing seems to work inbound or outbound for calls. Texting and Data are fine.
Login to the community
