Recently joined KOODO, and not yet set up to save incoming calls.  How do I do that and how do I retrieve saved messages?  And when asked to set up a “voice mail number” how do I do that?
Which phone are you currently using?
Hello Milky Way, thanks for responding. I am using Samsung Galaxy 21 FE.
You can set up your voicemail by following the steps in the link. Messages will be stored for 10 days. https://www.koodomobile.com/en/help/voicemail
Thanks a lot. That’s very helpful, MilkyWay.
Regards
