How can I enable callforwarding when I am already abroad?
So if you have a postpaid koodo account it is an add-on that can be found in koodo self serve that can beĀ added for $5 a month and becomes active immediately.
Once added, you can follow the steps in the link below to set up the call forwarding. Just be mindful that you will incur roaming charges to set up the call forwarding if you're already out of country as you will need to send a text message with the activation code. I hope this helps
https://www.koodomobile.com/en/help/call-forwarding
Ā
Since you are traveling, I just want to Note that you canāt forward to an international number, but you can forward to a US number, but you will be charged long distance per minute.
There are no additional long distanceĀ fee to forward to a Canadian number.
If you do not get the call forwarding add-on you will be charged per minute for forwarded calls.
Login to the community
